Discussion topic: Pin
Message posted on 15 Sep 2025 09:49 PM
Pin
Can I put a pin on the Wi-Fi to stop kids at home a time I like
Message posted on 15 Sep 2025 09:57 PM
Re: Pin
@Becca52 If you have sky Max you can look to setup the Parental controls and scheduling as you require!
Message posted on 15 Sep 2025 10:04 PM - last edited: 15 Sep 2025 10:07 PM
Re: Pin
There's no PIN mechanism. As @JimM1 indicates there are Parental Controls included in the WiFi Max subscription supplement, or you could attach a separate wireless access point to the Sky Hub and switch the signal from it on and off as required while keeping the password for the Hub WiFi secret.
