10 Nov 2024 10:35 PM
10 Nov 2024 10:44 PM
My 2 TV went out at the same time up stairs
11 Nov 2024 07:25 AM
Posted by a Superuser, not a Sky employee. Find out more@babybeau1 & @Helenmclean assume you are streaming the programme? If so check other channels to see if tge issue is with the broadcast or not. If all channels have gone check other devices if they are still connected to the internet then the issue is likely to be a poor WiFi signal to the Sky puck orcwhstever device you are using. If all devices are down check the Sky hub as its lights will show if its lost connection.
