05 Apr 2024 10:08 PM
Hi daughters iphone won't connect to internet - message is no internet connection in orange writing
other phones and devices have connected after having that message at start
06 Apr 2024 07:15 AM
Posted by a Superuser, not a Sky employee. Find out more@Joy63 if other devices are connecting there doesn't appear to be an issue with your hub or broadband service.
Check the network settings on the phone as that is likely to be the issue. To connect the phone needs to have received an IP address from the hub in the range 192.168.0.2 to 192.168.0.254 the easiest way to get that is make sure the phone is set to get network details automatically.
If really stuck tell the phone to forget the connection then power it down fully how to do that depends on the phone. Then restart itand once it fully reboots add the connection from scratch.
