Discussion topic: Phone line issues since upgrading to Sky Q
Message posted on 30 Dec 2023 11:36 AM
Message posted on 30 Dec 2023 11:41 AM - last edited: 30 Dec 2023 11:49 AM
Re: Phone line issues since upgrading to Sky Q
A Q booster cannot help a cordless phone signal: voice calls on a 'landline' may be travelling over the internet from the router, but they do not use local WiFi at all.
Is the hardware plugged into the Sky Hub a DECT base station?
Message posted on 30 Dec 2023 11:44 AM
Message posted on 30 Dec 2023 11:45 AM
Message posted on 30 Dec 2023 11:53 AM - last edited: 30 Dec 2023 11:56 AM
If the handset or DECT base is plugged into the Hub then you are using Sky Talk Internet Calls: since September 2023 this is the only option for new or switched broadband provision.
Unfortunately with that technology any internal phone master or extension sockets will no longer function.
One thing to try is to relocate either the Hub, the phone base or both to the maximum distance permitted by their existing cable lengths, preferably in opposite directions, and then to try longer cables bought elsewhere.
Message posted on 30 Dec 2023 12:00 PM - last edited: 30 Dec 2023 12:02 PM
@Averil wrote:
One said a box booster would help
The booster does help WiFi coverage, but a cordless phone plugged into a Hub isn't using WiFi between handset and base: it operates on a different wireless technology which the booster isn't boosting (and may in fact be interfering instead). It's not ideal to have a WiFi router and a cordless phone base adjacent to each other.
Message posted on 30 Dec 2023 12:02 PM
Message posted on 30 Dec 2023 12:08 PM - last edited: 30 Dec 2023 12:21 PM
Essentially you can't 'boost' a cordless phone: their power output is limited by national regulation. What you can try to do is minimise any potential interference between the two different wireless technologies, and potentially relocate either the phone base or the Hub or both to put them in a better position to carry their signals in the property.
As a first step, move the phone base as far from the Hub as possible on their existing cables: if they are currently right next to each other then that's likely to be a problem in itself.
Message posted on 30 Dec 2023 12:17 PM
Message posted on 30 Dec 2023 12:24 PM - last edited: 30 Dec 2023 12:27 PM
Yes, the change in base station location could well be an issue. Note an ethernet cable is only relevant between an ONT and a Hub though, where the broadband is delivered over FTTP: if it's not FTTP then the relevant cable to relocate a Hub or a phone base is two or four wire with RJ11 and/or 'BT jack' plugs (ethernet uses RJ45 plugs and those don't fit 'phone' sockets)
Message posted on 30 Dec 2023 12:30 PM
That is the way to go, if the original position of the phones was NOT causing you issues before your upgrade it may return to normal, The remote handset always has to communicate to the base station.
Please remember you also have the booster for wifi, make sure that it is not located near your cordless phone also. You can switch the booster off if you need to test your phone keep that in mind.
Message posted on 30 Dec 2023 12:36 PM - last edited: 30 Dec 2023 12:53 PM
FTTP: To move a Hub further from an ONT needs Cat5 ethernet cable with RJ45 plugs at each end.
ADSL/FTTC/G.fast: To move a Hub further from an Openreach filtered faceplate wall socket needs a 'modem' cable with RJ11 plugs at each end.
To move a handset or wireless phone base further from a Hub needs 'phone' cable with RJ11 at one end and a BT jack on the other.
Note a standard analogue phone handset or DECT base cannot be made to work by connecting to an ethernet socket on the Hub even if a plug/cable combination permits this physically.
Confusingly RJ11 and RJ45 are very similar visually, but RJ11 is smaller.
