Discussion topic: Phone line disruption
This message was authored by: Happy+Gardener
My wifi connection randomly daily, but consistently gets disconnecting. This means that my sky mini hub in separate room disconnects and freezes whilst viewing. Also my cctv which relies on good phoneline connection becomes offline. All equipment has been tested inside house and everything is working. Issue is from house to telephone pole outside. As i am with sky, please advise house to proceed to get problem fixed.
Re: Phone line disruption
@Happy+Gardener Run the check below and if it does not find anything do the last part you do appear to be convinced that you have nothing internal going on so what makes you say that!
Try running the line test here to see if any faults are found:
