Discussion topic: Permissions on router?
This message was authored by: -Waterford-
Message posted on 25 Feb 2025 06:09 PM
I'm trying to use my laptop to connect to my work VPN. I have already spoken to you, you've sent me help information, but it has not solved the issue. I have changed the shield setting etc as instructed. My VPN still shows the same error, but I can connect to it from every other wifi network and via hotspots.
Find out more
Message posted on 25 Feb 2025 06:12 PM
Re: Permissions on router?
Is that a white Max Hub?
