Discussion topic: Peak times
This message was authored by Cally93xo This message was authored by: Cally93xo
Peak times
I am unable to get wifi on my second TV during peak times. I am aware that it is due to traffic. Is there anything I can do to fix this without having to pay extra money per month as I cannot afford it. Any help would be great.
Thanks in advance
Re: Peak times
@Cally93xoWould seem that you are talking about a lot of others around you on the same Wi-Fi frequency. You can manually change this or reboot the router to see if it gives you a much cleaner frequency.
To see which one you are on login on your router and click on the Wi-Fi tab at the top. You have the 2 tabs one for 2.4 and 5.0 Ghz. It could be the 2.4 GHz is congested that can be changed to 1,6,or 11 depending what it is on. If you change it then save the changes to see if this helps out with the TV.
Cally93xo
Re: Peak times
  • Great, thank you very much 🙂
