Discussion topic: Password for wifi
This message was authored by: Catherine5646
Message posted on 16 Aug 2024 09:01 AM
Password for wifi
Says incorrect password everytime I connect
Find out more
Message posted on 16 Aug 2024 09:35 AM
Re: Password for wifi
@Catherine5646 if its a single device tell the devicecto forget the connection then fully reboot iit and add the connection from scratch as one cause is the device's memory position holding the password gets scrambled.
If its multiple devices check you are reading the code correctly as it is quite sasy to misread say a number 0 as the letter O.
