22
This discussion topic has been answered Discussion topic: Password for the settings
This message was authored by: Loogpy
I need to know the default username and password for the settings on my sky adsl router when I go to 192.168.0.1
Re: Password for the settings
@Loogpy
Depending on which hub you have, the password is either sky or your WiFi password.
@Loogpy
This message was authored by: FLC
... with username: admin.
This message was authored by: Tony_73
I have same issue and hjave reset my router but admin - sky   and admin -(wifi password) are not working    any advice please
Hi thanks its an SR203
@Tony_73  If you have reset the router then you will have to use the Wi-Fi password along with the username of admin to log into the rotuer. This can be changed if you wish to do so once you have logged in.
The Wi-Fi password works as both the Wi-Fi password and your log in password default out of the box or if you reset the router as you have done so.
apoliogies , ive done that and no joy in short
i have reset
opened 192.168.0.1
selected to change wifi channel
tried   admin as the username and the wifi password as the password
no joy
tries admin and sky
no joy
forgotten the network on my phone and reconnected agaiin sucessfully with the wifi password
@Tony_73  You are not changing the Wi-Fi channel you are trying to log into the rotuer. How long did you hold the reset button for when you did the reset?
thanks for your help Highlinder but I have just reset agin - pressed reset button for 10 seconds and tried again , no joy
192.168.0.1 gives overview status page , but i want to chnage the wifi band , when i select that i am failing the log in with the earlier details
@Tony_73  Are these the details on the back of the router that you are using to sign in with?
yep thats them , i used them after  i selected forgot network on my mobile and that was fine its just when in the admin page i cant use these creds to log in to make changes
@Tony_73You are typing in admin in all small letters and not with a capital A. When you type in the creds do the page just refresh? What broswer are you using?
Its a pop uo saying sign in to access this site
im using edge
no caps     have tried cut and past  and typing too many times defo not a typo error
oh and the log in box just refreshes to empty fields
