Discussion topic: PaloAlto GlobalProtect
This message was authored by: Erdbeerfelder
I am having real difficulty connecting to the Paloalto GlobalProtect product to allow me to access my work systems. Does anyone have any suggestions to help. I keep getting 'The network connection is unreachable or the portal is unresponsive. Check the network connection and reconnect'
Re: PaloAlto GlobalProtect
@Erdbeerfelder As it say's you need to check that the security portal is up and running, this is nothing that sky would be blocking.
@Erdbeerfelder
Are you using a white Sky Max Hub?
Avatar for Erdbeerfelder
Yes I am
@Erdbeerfelder
In that case the pinned post at the top of this forum is relevant.
https://helpforum.sky.com/t5/Broadband/Having-problems-with-a-3rd-party-VPN-and-have-a-Hub-6/td-p/48...
Typically the issue is the deployment by Sky of IPv4 address sharing through Map-T on broadband circuits that land on a Max Hub.
Thank you, I'll take a look at the post.
This message was authored by: Carlbrennan
Same issue on black sky router. Exact same message and when I try to connect to landing page for vpn I get this:
 if I disconnect and connect via my phone it instantly works...???
