Discussion topic: PPPoE setting Fttp for Ipv6
This message was authored by: UkzVortex98
I am try set up IPV6 on my tp-link AXe5400
I need sky FTTP PPPOE
Username
Password
Screenshot 2025-09-21 110402.pngScreenshot 2025-09-21 110402.pngScreenshot 2025-09-21 110438.pngScreenshot 2025-09-21 110438.png
Re: PPPoE setting Fttp for Ipv6
@UkzVortex98 Why are you trying to use PPOE for the connection type!
Avatar for UkzVortex98
That's what it's asking for
@UkzVortex98 Sky does not use PPOE in the UK for connection authentication!
Yes it does that only way I can set up
@UkzVortex98 No problem, you may find the Tp-Link site better for your answer then or search the Forum to see who has managed to connect a Tp to the system and requirement to get an iPv6 working with it!
@UkzVortex98
Sky UK doesn't use PPPoE.  You could try choosing DHCPv6 delegation if that's available on the TP-LINK
Not all routers are compatible with Sky, and not all exchange areas provide DHCPv6
This message was authored by: Sayek
@UkzVortex98
Another fellow TP-Link user...a fine choice 😎
I previously connected similar router the TP-Link AX73 and now have a Deco X50.
Its Dynamic connection and needs IPv6.
Below is the guide
https://www.tp-link.com/uk/support/faq/2642/
