Discussion topic: PON light on ONT unit lit RED
This message was authored by: AlexS1967
Hi, Could anyone please tell me how I can fix the Red PON light on the ONT unit fitted in my house today ? The Openreach engineer was present some time and was having problems splicing the fibre. He was adamant that the fibre was ok and the SKy router or service was at fault. I now have no internet or phone service. I've since visited a friend to use their broadband and discovered that after a power cycle of all the equipment a constant red PON light most likely means a poor or faulty fibre splice ! Thank you
Re: PON light on ONT unit lit RED
@AlexS1967 you would need to report it to Sky who can then request an engineer visit as it sounds like the openreach engineer hasn't spliced it properly
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for AlexS1967
Thank you. I'll try that number.
Hi, I tried the number suggested and got through to Sky Support. They recommended another visit by an Openreach Engineer to investigate. The 2nd Engineer visiting this morning and checked everything. It appears the 1st Engineer who visited on Monday 16th hadn't registered the ONT unit correctly so it couldn't connect and provide a live service. Everything is now working as expected. Thanks very much @Laing1 for your help.
