Discussion topic: Overheated phone. Works fine but can't connect to the WiFi?
Message posted on 13 Aug 2024 07:36 AM
Message posted on 13 Aug 2024 07:52 AM
Re: Overheated phone. Works fine but can't connect to the WiFi?
@LJRICHES10 very unlikely to be an issue with the hub if other devices connect normally. Depending on the degree of over heating your phone could have been damaged but let's hope not. Try telling the phone to forget the Sky connection then do a full re-start of the phone so it reboots fully which should lear its memory. Once restarted add the Sky connection again.
@LJRICHES10 To rule out that there could be damage to the phone have you tried to log on to another Wi-Fi that you have to type in the password to see if it will connect to that.
Message posted on 13 Aug 2024 09:39 AM
Yes. It works fine with other wifis
