Discussion topic: Orange light
Message posted on 19 Aug 2026 08:58 AM
Orange light
Orange light with no WiFi no connection to tv. I've tried rebooting nothing worked
Message posted on 19 Aug 2026 09:08 AM
Re: Orange light
@Wifi100
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
