3
This discussion topic has been answered Discussion topic: Orange light on router
This message was authored by: Scimitargtc
I have a Yale Wi-Fi alarm and when plugged into my sky router 1 light is flashing green which I guess is traffic, the other is solid orange whereas my domestic phone port both lights flash green, I'm losing connectivity to the alarm hub regularly which would alert me remotely if there was an activation.
Re: Orange light on router
@Scimitargtc @the Ethernet indicators are acting normally the amber light indicates a connection at 100Mb/s and if its Green its Gigabit. Alarms dont need high speed connections so probably only has a 100Mb/s capable port.
There was an issue with Yale alarms which was fixed by Sky rolling back a firmware release so check if your hub is running a firmware release such as 07.00.04 rather than 07.00.05.
Which light is orange?
Avatar for Scimitargtc
Reverse of the router where the rj45 plugs onto the socket. Left hand lamp is solid orange right is flashing green
