Discussion topic: Orange light flashing
Message posted on 08 Jul 2026 08:05 PM
The light keeps flashing and the internet is not working but the checks I just did say it is! But it's not!
and as usual can never talk to anyone even though I pay a lot of money each month to you!
Message posted on 08 Jul 2026 08:07 PM
Re: Orange light flashing
Not to us. You haven’t actually contacted Sky Customer Services by posting on here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
