Discussion topic: Help please
This message was authored by: LozzaW60
Help please
On modem the
power light is green
no light on interbet
wifi light is green
vouce light is red
there are no issues in area.
I have reset the modem
I have switched the power off and on
no difference
please can somebody help me. Thank you 😀😀
Re: Help please
@LozzaW60
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
This message was authored by: Jess233
Re: Help please
I'm having the exact same issue with red "voice" light. All test links say there is no issue but I have no internet access and all devices have been disconnected
Avatar for LozzaW60
Re: Help please
Mines just gone down again. Totall ball ache trying to constantly link to the internet.
Will try @Daniel0210  tricks to see if they help
Avatar for LozzaW60
Re: Help please
I've just spoken to Sky on the phone via my Vodafone mobile. They were amazing!! All sorted. Well done Sky! 👏👏👏👏
Avatar for LozzaW60
Re: Help please
Internet has gone down again and miraculously SKY have just said there in an outage in Portsmouth
Re: Help please
@LozzaW60
You can use this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
