Discussion topic: Orange internet light after power cut
This message was authored by squidlimerick This message was authored by: squidlimerick
My sky broadband hub is not connecting to internet after a power cut.  Ive done all the resets and stuff but no joy
Lights on router are
Power green
Internet orange
Wifi green
Phone off
Sky customer care is useless as it closes at 6 or 7 pm
Re: Orange internet light after power cut
@squidlimerickCould you check that there is no further problems in the area by running a broadband test.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
This message was authored by Deadleg This message was authored by: Deadleg
We just had this happen. All lights showing green. Replaced the modem, working now.
