1
This discussion topic has been answered Discussion topic: Openreach square box ultrafast
This message was authored by: Chloe142
Hi having had ultrafast installed yesterday, the square white box that supplies the cable and plugs for the hub, should the LAN light on this box keep flickering many thanks
This message was authored by: cookiemonsteruk Answer
Re: Openreach square box ultrafast
@Chloe142
A flickering lan light on the ont means data is flowing between the ont and router. Its perfectly normal
@Chloe142
