This discussion topic has been answered Discussion topic: OpenReach cables
Message posted on 29 Jan 2024 12:56 PM
We've just signed up to a new Sky broadband contract, after years of using other providers. OpenReach installed fibre cables in our road a couple of years ago and we know that we have the right connection up to the property boundary. However, I've just received this message:
Openreach need to lay the casings which will protect the cables from damage. This will be from the telephone exchange to your property. Further work will be required when this is completed.
It doesn't make any sense. The cables are there, laid and being used by neighbours. It doesn't seem possible to reply to the message on my request to get more information from Sky support staff. So, I'm posting here in the hope that someone from Sky can find out what's going on. I know that a cable needs to be laid from the front of the property up to the house, but the message says from the exchange - that sounds like massive amounts of digging up roads and therefore months of waiting.
Message posted on 29 Jan 2024 12:58 PM
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Message posted on 29 Jan 2024 01:45 PM
Re: OpenReach cables
It says:
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG Pre built to curtilage Hard.
FTTP is available and a new ONT may be ordered.
Message posted on 29 Jan 2024 01:52 PM
Message posted on 29 Jan 2024 02:17 PM
That indicates you are getting a full fibre connection which is only up to the perimeter of your property. Openreach will have to lay underground fibre right up to the outside wall and then install a fibre optic modem (ont) inside
Message posted on 29 Jan 2024 02:20 PM - last edited: 29 Jan 2024 02:22 PM
And it's flagged as a 'Hard' dig (i.e. through tarmac/concrete/brick) rather then 'Soft' (soil)
Message posted on 29 Jan 2024 02:38 PM
Yes, I was expecting them to need to dig from pavement to house, but the message from Sky says from the exchange.
I think the ground is neither hard nor soft, it's a gravel drive so not concrete but not lawn either.
Message posted on 29 Jan 2024 02:50 PM
That message is a generic message that was used when the delay was worked by sky, either the agent miss read the delay notification or openreach have left vague notes on your order
Message posted on 29 Jan 2024 03:01 PM - last edited: 29 Jan 2024 03:16 PM
I believe anything but turf/flowerbed is 'Hard' in Openreach terminology.
Message posted on 04 Sep 2024 01:38 PM
My question is: can Sky be used through the cable? we are moving to the house with the cable.
Message posted on 04 Sep 2024 01:43 PM
What cable do you have?
Could you enter your full address where you broadband is to be installed and post the table and notes after removing your address from the image
Message posted on 04 Sep 2024 01:46 PM - last edited: 04 Sep 2024 01:47 PM
Sky Broadband cannot be delivered over the Virgin coaxial cable network, if that's what you mean. It also cannot currently use optical fibre laid by anyone but Openreach.
