8
This discussion topic has been answered Discussion topic: Ont power cable missing
This message was authored by: KieranWenlock
How do I go about getting a new Ont power lead just moved into property and seems as old rental has taken it
Re: Ont power cable missing
@KieranWenlock quite why people nick the power supply defeats me. Call Sky and they will get Openreach out to replace it but thst may not happen until after the service goes live.
Avatar for KieranWenlock
Awesome thank you will try find there contact number was getting nowhere with the automated bot. My services are live
@KieranWenlock there is no number thst bypasses the bot but try not to engage with the infernal thing and you s hould becrouted to an agent.
Thank you so much for you help
This message was authored by: agarroad88
Did you manage to get a cable?
Same issue with us - no power cable. Getting no help with the SKY bot or via telephone. Frustrating as hell!
This message was authored by: Emma599
Did you manage to resolve this? I have the same issue. Can't get through to an actual person to discuss it with
I couldn't either - my husband just bought a multi-ended lead from argos which worked!
argos product: Masterplug Voltage Adapter982/9701
@agarroad88 using a third oarty power supply  not recommended as there are mutiple models of ONT in use and while that unit msy work on yours it could damage another unit. The ONTs belong to the network operator who are either Openreach or City Fibre if you damage one you will be charged . Always ask Sky to arrange a proper replacement normally a quick call sorts this out.
