Discussion topic: Only 1 bar on wifi
Message posted on 07 Jul 2024 12:25 PM
Only 1 bar on wifi
I only have 1 bar on my wifi.... when i check wifi and broardband it show a problem but when i test it .. it says its ok? Never get more than 1 bar...i seem to using up a lot if data on my network... but not sure why as i use the wifi
please gelp
thank you
Message posted on 09 Jul 2024 03:02 PM
Re: Only 1 bar on wifi
How far away from the router are you? Of course you can only expect 1 bar if you are a good distance away
Message posted on 09 Jul 2024 03:04 PM
I am in the same room
Message posted on 09 Jul 2024 03:26 PM
@Topper90 Please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
