2
This discussion topic has been answered Discussion topic: Online checker does absolutely nothing to help
This message was authored by: LoneWolf4716
So my broadband router is showing amber for Internet and voice and fibre bos 3 green lights,
So I go onto service checker and its showing greens across the board.
I test it further by removing power supply from router check comes back the same as well as if I turned off the fibre power something tells me the service checker is just a bunch of **bleep** as it wont let you then troubleshoot further dispite what it says
Re: Online checker does absolutely nothing to help
@LoneWolf4716
When it is down after midnight to around 6am then it could be overnight maintenance taking place as per this message at the top of the page:
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/m-p/5151847#...
If it still down later then the first thing to check is this link to see if there are any outages in your area, it doesn't always pick up issues straight away so it might be worth trying again later if this is the case:
If your ONT shows a red light then have a read of this:
If there isn't try running the line test here:
Avatar for LoneWolf4716
Sorry for the couple of grammatical errors my phones auto correct is stupid
@LoneWolf4716
