2
This discussion topic has been answered Discussion topic: Old router box
This message was authored by: tomswanwick
Old router box
Hello i upgraded a few months ago and i still have my old router,sky never asked for it back so do i dispose of it?? Thanks
This message was authored by: stereohaven Answer
Re: Old router box
Sky do not always ask for older kit back, especially older routers/hubs like the Sky Q hub.
You can send it back to Sky anyway, follow the instructions here: https://www.sky.com/help/articles/return-or-recycle-sky-equipment
Alternatively, there should be plenty of options to recycle responsibly locally I suspect. Here we can put small electrical items like that in a bag and they are collected with the normal weekly rubbish, or we can drop it off at a recycling centre - check with your local council.
You could of course just put it in the bin but, that is up to you.
Re: Old router box
Avatar for tomswanwick
Level 0 icon
Re: Old router box
Thanks its an old one i will just throw it out,thanks for reponse
