Discussion topic: Old broadband/telephone cable
Message posted on 01 May 2026 03:50 PM
We had Sky full fibre installed at our property in August 2025. Could somebody please advise who I need to contact to have the old broadband/telephone cable taken down as we are now having all the fascia and soffits replaced and it seems daft to reconnect wires to the new ones that are not in use. The wire goes directly to a telegraph pole opposite our house.
Message posted on 01 May 2026 03:57 PM - last edited: 01 May 2026 03:57 PM
Re: Old broadband/telephone cable
It's your choice to remove internal cabling beyond the master socket, and realistically you could have that out too.
You shouldn't touch the cable between the property and the pole even though it's no longer in use: strictly speaking cutting it at the house end and allowing it to drop would be illegal.
At some point Openreach might decide to retrieve street cabling for its scrap copper value.
Message posted on 01 May 2026 06:21 PM
@Blackjack1965 if you are having work done that will affect the cabling talk to Sky as Openreach should becable to help.
