Discussion topic: Internet not working
This message was authored by: 1wona
over the past 3 days my router has not been working. I'll have internet for an hour and then it'll fully turn off, the lights on the router start blinking, I lose internet for 3 hours then it comes back for a few minutes. I've tried resetting it and pretty much everything but it just does not work.
Re: Internet not working
@1wona
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
