10
This discussion topic has been answered Discussion topic: Ol4 outage?
This message was authored by: Sky+Hubs+are+naff
Ol4 outage?
Internet is down in Oldham for sky?
my router has a green then amber then green then amber light
suppose to be working from home so not great
Avatar for Sky+Hubs+are+naff
This message was authored by: Sky+Hubs+are+naff Answer
Re: Ol4 outage?
Issue must have been a local one as working again now
hope same for others impacted
Re: Ol4 outage?
@Sky+Hubs+are+naff
If you haven’t done it yet use this link to check to confirm if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
This message was authored by: AMoore01
Re: Ol4 outage?
Having the same issue here, OL4
Re: Ol4 outage?
Many thanks for the response ... been round in circles with the test saying an issue they'd fix it then says all fine and prompts to come here
Looks I need to call grrrr
Re: Ol4 outage?
Anyone got a number I can call from a mobile as online just loops to online hep and no way to actually call
Re: Ol4 outage?
Have you managed to get in touch with sky to see if local issue please and thus when likely to fix? Just hoping you have had better luck than me thanks
This message was authored by: SamanthaConway
Re: Ol4 outage?
Problems in ME2. Saya everything is connected and working but won't connect to the Internet. Working from home so not your helpful 😒
Re: Ol4 outage?
Problems in ME2. Says everything is connected and working but won't connect to the Internet. Working from home so not very helpful 😒
Re: Ol4 outage?
@Sky+Hubs+are+naff
To call Sky dial 150 (free) from either your Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The forum filters don’t allow the posting of full phone numbers on here.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Re: Ol4 outage?
Spent over 40 Mins on call with them and engineer due out tomorrow and new router on order as back up but ask still looking into a possible wider local issue so hope it gets sorted for you too!
Re: Ol4 outage?
