Discussion topic: OPENREACH CONNECTION IS FAULTY
This message was authored by: Bobbyr944
Message posted on 25 Aug 2024 03:22 PM
My open reach modem usually has 3 green lights, for the last half hour the LOS light is red and will not connect.
I have tried to restart it and had no success. There's clearly a fault somewhere. Reporting faults to sky is so difficult can someone help please.
Find out more
Message posted on 25 Aug 2024 03:29 PM
Re: OPENREACH CONNECTION IS FAULTY
@Bobbyr944 Have you tried to call Sky to report this fault? Have you ran the Service checker to see if it picks up the fault?
