1
This discussion topic has been answered Discussion topic: ONT FTTP box and third party router setup advice.
This message was authored by: Jeffrrzuk
Hi I've just moved into a new place and was supposed to go live with VM.
Turns out the property doesn't have a access point.
The move was a mutual swap. The previous tenant I believe had sky and the connection is still live for a couple of weeks.
I have a Mercusys MRG50.
Could someone tell me the setting I need to use to acess the network?
The openreach ont box has power, PON and LAN on with solid green. The LOS is off.
Thanks.
Kind regards,
Jefferz 🙂
This message was authored by: cookiemonsteruk Answer
Re: ONT FTTP box and third party router setup advice.
@Jeffrrzuk
Heres one i sorted out for a customer with a different mercusys model. Hopefully it will work on yours
https://helpforum.sky.com/t5/Broadband/Mercusys-H80x/m-p/4452383
@Jeffrrzuk
