Discussion topic: Number of devices
Message posted on 03 Dec 2024 08:17 PM
Number of devices
Good afternoon, does Sky have a limited number of devices allowed to be connected?
We have 2 TV's, 1 laptop and 3 phones connected and it's not allowing us to connect our 3rd TV
Message posted on 03 Dec 2024 08:33 PM
Re: Number of devices
ISP routers do have functional limits, but they aren't anywhere near that low.
In what way is the television 'not allowed'?
Message posted on 03 Dec 2024 09:36 PM
Hi, thank you for your reply. When I put the password, it doesn't work.
Message posted on 03 Dec 2024 09:43 PM - last edited: 03 Dec 2024 09:57 PM
If that's a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
Some television sets connect more easily using a WPS button press rather than password entry.
Message posted on 03 Dec 2024 09:45 PM
Will try tomorrow, thank you for your valuable advice. 🙏
