Discussion topic: Not working
Message posted on 08 Jan 2026 06:52 PM
Not working
My WiFi is not working it says it's connected am working but it's not
Message posted on 08 Jan 2026 06:55 PM
Re: Not working
@Amya
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
