Discussion topic: Not working
This message was authored by: Ashleyr2
Not working
My internet is not working. The first light is on the second is off, the third is on and the fourth is orange
Re: Not working
@Ashleyr2
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Re: Not working
@Ashleyr2 You may also have been in this event so have a read at the link!
Important Information: Scheduled Broadband Mainten... | Sky Community
Avatar for Ashleyr2
Re: Not working
Hello, it's now way last the time or the event you sent and it's still not working! What can you do??
Avatar for Ashleyr2
Re: Not working
It's all sorted now and back on. Thanks anyways
