Discussion topic: Not working
Message posted on 28 Apr 2025 06:29 PM
Not working
It's say on the sky app that everything is working as it should , as I have just checked . But looking at the router it's not
Message posted on 28 Apr 2025 06:39 PM
Re: Not working
Having the same problem here.(Molesey)
Message posted on 28 Apr 2025 06:53 PM
Re: Not working
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
