Discussion topic: Broad band
Message posted on 28 Apr 2025 06:42 PM
Broad band
Hi my broad band is not working
Message posted on 28 Apr 2025 06:51 PM
Re: Broad band
@Jamesstanley
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
