Discussion topic: Not working brodband
This message was authored by: Mitra22
Hi sorry i just to say my broadband connection is not working and it has not worked
Re: Not working brodband
@Mitra22
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them so they can look in to this for you.
