Discussion topic: Not workin
This message was authored by: Katherine32
Not workin
Internet has stop working?
Re: Not workin
@Katherine32
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
