Discussion topic: No wi fi
This message was authored by: Williamav54
No wi fi
The Internet keeps crashing.  Over the past 3 days several times per day
Re: No wi fi
@Williamav54 No wi-fi or no broadband internet, both are different?
Re: No wi fi
@Williamav54
As stated by @JimM1 Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (Sky).
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
