06 Jun 2024 05:24 PM
Hi All,
im hoping somewhere someone has experienced my issues and can help me?
when opening emails I keep getting a message saying "Cannot download from the server"
and the email is blank, does anyone know what's causing this and how I can fix it? As it's so annoying when your waiting for an email and then you can't read it.
06 Jun 2024 05:29 PM
Might be worth checking the Broadband Shield age setting and moving it to a less restrictive level.
06 Jun 2024 05:39 PM
Posted by a Superuser, not a Sky employee. Find out moreAs well as Sky Shield this can also be caused by iCloud relay if you have an Apple device
07 Jun 2024 08:38 AM
Hi
Checked the broadband shield and it's set only Adults only!
07 Jun 2024 08:40 AM
Any idea on how to check it and what to do to fix it?
Its nothing to do with Broadband Shield.
11 Jun 2024 10:24 AM
Posted by a Superuser, not a Sky employee. Find out moreSometimes adult setting still blocks things, try disabling it completely.
A simple Google search would give you the result on how to disable iCloud relay
https://support.apple.com/en-sg/guide/iphone/iph499d287c2/ios
