Discussion topic: Not receiving wall to wall wifi
Message posted on 12 Feb 2026 06:04 PM
Two rooms reviving very weak signal. One room generally receives no signal at all
Message posted on 12 Feb 2026 06:19 PM
Re: Not receiving wall to wall wifi
@Pete210 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
