Discussion topic: Broadband crashng
Message posted on 11 Feb 2026 05:19 PM
Broadband crashng
Broadband crashes every night (used to be about 2.30am each day but now 5.15am each day).
No access to Sky TV and all devices reconnect after approximately 10 minutes.
Message posted on 11 Feb 2026 05:20 PM
Re: Broadband crashng
Hi @Andys211
Do you have Sky Q?
What broadband package do you have and which technology is it using (FTTC or FTTP)?
Message posted on 11 Feb 2026 05:23 PM
Yes I have Sky Q. Broadband is Fibre300 (was 100 but upgraded). No idea about the rest.
Message posted on 12 Feb 2026 03:04 PM
Then its likely the power saving settings on your Sky Q box. Change them from Eco to Active in settings
Message posted on 12 Feb 2026 03:11 PM
I agree with @jamesn123 This link explains changing the Eco mode settings
https://www.sky.com/help/articles/using-the-standby-settings
Message posted on 12 Feb 2026 03:39 PM
No. The eco setting is already off.
Message posted on 12 Feb 2026 06:34 PM
Not sure what else is causing it then, do the lights on the hub change? If its a single 10min outage in 24hrs its not likely to be accepted as a fault by Sky or Openreach
