Discussion topic: Not internet
Message posted on 25 Dec 2025 08:18 PM
Not internet
Every time 6-8 times a day doesn't work internet
Message posted on 25 Dec 2025 08:22 PM
Re: Not internet
@Oleksandr4
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
