Discussion topic: Not happy
Message posted on 15 May 2025 02:31 PM
Not happy
Switched to your service recently but it keeps dropping out and the tv keeps freezing, have done checks online it says everything is ok but that is not the case very disappointed with the service, can you fix it or cancel my account, never had an issue with virgin
Message posted on 15 May 2025 02:38 PM
Re: Not happy
@Unhappywith
The Sky Community is a customer led discussion forum where Sky customers are available to help other customers. You are NOT contacting Sky Customer Services.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
