3
This discussion topic has been answered Discussion topic: Not connection with my broadband
This message was authored by: AnaCristinaRJ
I have a problem with my broadband connection since yesterday until today and I can't sort out the problem by phone I need more help because I don't know where is the problem come from, can you help please fixed the trouble
Re: Not connection with my broadband
@AnaCristinaRJ
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
@AnaCristinaRJ
Avatar for AnaCristinaRJ
Thanks for your answer but just I tried everything everything but I'm still have a problem not broadband not connecting  
@AnaCristinaRJ
As stated then
