Discussion topic: No wifif connection
This message was authored by: Haifamoal
No wifif connection
The WiFi works in some rooms upstairs but is not working at all downstairs I have got sky booster downstairs which used to work perfectly but three days ago stopped working completely I tried to switch off and on but the issue still there
Re: No connection
@Haifamoal
Try running this line test to see if it finds any faults:
Re: No wifif connection
@Haifamoal
Where is your broadband hub located, upstairs or downstairs as the booster needs to be halfway between it and the rooms you have no connection in.
Avatar for Haifamoal
The booster is downstairs, it used to work perfectly as it should for 2 years but suddenly stopped working two days ago
This message was authored by: Me134
And where is the main hub? Try plugging the booster into a different socket but in the same room as the main hub, if no success you'll need to contact Sky for a replacement.
Phone or chat with Sky directly. Either 150 on a Sky broadband landline/Sky mobile or have a look at https://www.sky.com/help/articles/contacting-sky
Not a Sky employee
Sky FTTP 500Mb to Max Hub
