Discussion topic: No wifi
This message was authored by: Jonathan1234
No wifi
Hi
We've got no internet, just ran the test on the sky app and it says it's ok but my phone and computer aren't connecting to the wifi
Re: No wifi
@Jonathan1234
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
