Discussion topic: No wifi
This message was authored by: Paul,+Colchester
No wifi
My phone says "connected without internet". The issue started around 14:25 UK time. I also have a PC and a laptop which are also unable to connect. All devices stopped working at the same time.
Re: No wifi
@Paul,+Colchester
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
This message was authored by: NickNewark
Re: No wifi
This also happened to me around 11am this morning. I always have a generally stable connection, I lost all my devices, even the router and the app showed no issues.
The main SkyQ box needed to be rebooted and the mini boxes, Tado,  both mobiles all had to be manually added back on to the network. I've noticed a few posts saying similar WiFi issues ? A known issue?
