1
This discussion topic has been answered Discussion topic: No wifi
This message was authored by: Helen336
No wifi
Hi,
my internet has suddenly gone down. There is a red light on the 'LOS' on the openreach master socket.
Re: No wifi
@Helen336
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Re: No wifi
@Helen336
