Discussion topic: No wifi
This message was authored by: Deacs1
No wifi
No WiFi Internet, sky test says it's all good.
Funny how we cant watch Internet driven programs and I have a orange light on our router
Thanks sky
Regards
Re: No wifi
@Deacs1
You may not be aware but you haven’t contacted Sky by posting here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
