Discussion topic: No wifi
Message posted on 06 Jul 2026 10:26 AM
No wifi
All lights are on the box and all green lights present but there is no WiFi to any devices in the house
Message posted on 06 Jul 2026 10:30 AM
Re: No wifi
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
Message posted on 06 Jul 2026 10:36 AM
Re: No wifi
I have the same problem
Message posted on 06 Jul 2026 10:39 AM
Re: No wifi
Message posted on 06 Jul 2026 10:44 AM
Re: No wifi
Having the same issue here. Except the Voice light is orange and the internet light isn't on. I've ran diagnostics through my Sky account and it say's my connection is good, but I don't have internet?
Message posted on 06 Jul 2026 10:49 AM
Emma
My router says connected but its not it's not connected to my phone and! I work from home and we pay sky over £160 a month? I need this fixed asap as effecting my job. I've disconnected and reset the router and shoes all green but not it's not working and and the app on here says there's an issue but I need thsi done asap!
Message posted on 06 Jul 2026 11:04 AM
Re: Emma
@Emma2026
You may not be aware but you haven’t contacted Sky by posting here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Message posted on 06 Jul 2026 11:05 AM
Re: Emma
Message posted on 06 Jul 2026 11:07 AM
Re: Emma
See my reply above your post.
Message posted on 06 Jul 2026 11:09 AM
Re: No wifi
Message posted on 06 Jul 2026 11:11 AM
WiFi outage across the country by the looks
Same as everyone else, green lights on, health check says fine but no WiFi, down detector shows loads of reports within the last 20 minutes
Message posted on 06 Jul 2026 11:12 AM
Re: WiFi outage across the country by the looks
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Re: No wifi
Same here
Message posted on 06 Jul 2026 11:13 AM
It's clearly a national problem if everyone has the same issue , it isn't a local or hub issue
Message posted on 06 Jul 2026 11:14 AM
It is not affecting everyone.
