Discussion topic: No wifi
Message posted on 18 Jun 2026 08:55 PM
No wifi
Have ran service check which shows all connections ok but still can't connect to the WiFi.
Message posted on 18 Jun 2026 09:07 PM
Re: No wifi
Me either
Message posted on 18 Jun 2026 09:41 PM
Re: No wifi
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
Message posted on 18 Jun 2026 10:17 PM
Re: No wifi
Hi @caesarome I have tried this and still get the same when running the sevice check - everything is ok.
The broadband check has a time stamp for 13:13. Even though Iv tried numerous tests this evening and it shows to be working fine.
Message posted on 18 Jun 2026 10:28 PM
Re: No wifi
Did you select broadband for it to run a more updated test ?
Message posted on 18 Jun 2026 11:05 PM
Re: No wifi
Me either
Message posted on 19 Jun 2026 08:12 AM
Re: No wifi
@GeenaZ wrote:Me either
Did you try the suggestions of @caesarome above your post?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
